Results 1 to 7 of 7
Thread: Moss for chlorine?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Moss for chlorine?
    I just saw a video clip on the internet where they are using moss up in MN I think it was, as an alternative to chlorine in pools
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Re: Moss for chlorine?
    Here is one article about it, and here is the company that sells the moss filter.
    Mar 2007
    San Rafael, CA USA
    12,082
    The video on it here as well as the article that Jason linked to (which looks like a transcript from the video) says it costs $30-60 per month depending on the size of the pool and the example they gave has a customer who still must use his saltwater chlorine generator (SWG) but it is set for the lowest amount the EPA allows which from the moss product website says it must be at least 1 ppm FC (though they don't refer to the CYA level).
    We already know that a low chlorine level will be sanitary (especially in a residential pool). The only issue is algae prevention and oxidation of ammonia and organics. Use of 50 ppm Borates would be a one-time alternative to algae prevention and one could even use PolyQuat 60 at $2-3 per week and accomplish pretty much the same thing. Keeping the FC level lower (with a high CYA) means the SWG can be turned down so less pH rise and associated acid needed to balance pH. So there's more than one way to accomplish this sort of goal -- even less expensively than moss.
    The thing is, even with those who keep 4 ppm FC with 80 ppm CYA in SWG pools don't complain about the problems that the guy in the video complained about -- irritated eyes, smell of chlorine, etc. I wonder what was really going on in his pool. I suspect his pH was fluctuating a lot and that he hadn't controlled a regular pH rise through the techniques described in this forum (lower TA, use of borates, higher CYA for SWG).
    Richard
    You can run at a FC of 1 with a SWG, a low CYA level, borates, and some very careful level balancing. Moss is not required. Plus it will have essentially all of the advantages they claim. Remember, they only say not to go below a FC of 1, they don't actually promise that you can get that low. Getting FC down to 1 is pushing it, but an FC level of 2 is not really all that difficult with an SWG and borates and a suitable CYA level.
    Even if the moss has the properties they claim, I can't imagine that a few cups of moss will do much for an entire pool for a entire month. If they were filling an entire 300 lb sand filter with moss I would be more inclined to believe it.
    Regardless, someone is being very clever about the marketing.
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Just watched the video, and well, if I have to spend $30.00 a month for moss, well no thankyou, if people would just come to TFP and see how you keep your water balanced for less than, lets say $10 a month.
    Lets see $30.00 a month hmmm 3yrs you could have a SWG.
    MOSS= Money Overspent Sewage Sauce and then they get it from New Zeland
    Maybe Al Gore might be interested
    Can you say Gimick
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    Guest
    I have 2 words--snake oil! (Does anyone remember pool magnets?)
    Or better yet "Moss for brains"
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    The name of the company is "Creative Water Solutions" and the product is "Pool Naturally."
    I'd say they are creative all right. The ignorance of the reporter in the video is typical. They never do proper research when reporting on these "alternative" solutions. Amazingly, any of the alternatives that are effective require regular testing, and maintaining a stable amount of free chlorine - hmmm, sound familiar?
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
