Thank you
Sounds ridiculous---but for now, we are siphoning with a hose-- ridic slow, but at least water is coming out steadily in a stream while we make lunch, put kids to naps, etc, LOL.
Does it seem like an okay idea to just keep that hose attached for a long while (days?)--draining-- and keep SLAM-ing?
This was a tight month as it was even before buying all the extra chlorine and $50 test kit, etc----and we don't have any extra $ to rent a pump, etc.
I appreciate all the guidance-- here are my main questions:
1. Can we keep draining with the garden hose for now? Should we add fresh water at a certain point to get CYA down faster (even though some will be drained back out by hose I guess)?
2. How many times a day should I be testing FC? Twice?
3. I don't think we can vacuum to waste-- when we first moved in, the inspector (who knows how much he knows about pools) said it was a brand new pump and filter but it was a brand he'd never heard of and it didn't look too professionally set up. (Awesome.) So-- I assume that means the only way we can drain is by renting a pump?
4. Can we keep SLAM-ing since we've already put so much time, effort, and $$$ in???
5. Is this a normal amount of FC to lose whicle SLAMing with algae??? Tested 9:15am it was 33, added chlorine using pool math to get to 39, tested again 1:15-- it's 33 again. Is that a normal amount to lose?
Thanks for the encouragement--- we are committed to doing TFPC but we are SO wishing we found this site 6 months ago right when we bought the house!!!
