Thread: Jandy filter help
    Jandy filter help
    Help I have a Jandy st-t 20 filter and I am not sure if the top plate that directs the water is in the correct rotation.
    If anyone has one of these can you please tell me what it says above the return or pump or waste fitting so I can line mine up the correct way.
    The only reason I believe I have it wrong is that when I added some stabilizer in the skimmer it came shooting out of the return.
    I thought it was supposed to stay in the filter?
    I had the valve set to filter so I think that the top plate which has the ports in it is wrong
    Thanks
    Sherra
    Kershaw County, South Carolina
    18x36 27,500 gal IG Vinyl Liner, sand filter, 1hp single speed pump running 6 hours twice per day, Hayward Swim Pure salt chlorinator, 2 skimmers, main drain, 3 returns, husband, 2 kids, 2 dogs
    Re: Jandy filter help
    got it, figured it out by taking it off again and examining the ports.
    Sherra
