Split off from a conversation originally started in this topic. JasonLion
Correct me if I'm wrong, but you have only used it 2 months or less. The OP has run with it for 2 years. Eventually the products build up the CYA too high and that leads to problems if you don't run with a corrsponding high enough FC level. See the chart. Running with the chlorinator "wide open" will only add more CYA and further aggrevate the already too high CYA situation.
NJpoolguy said:you are doing something wrong then. I use Synergy and have no cloudy water issues. You should not have to add anything. Do you have a auto chlorinator?? Run it wide open and add 1 tab per thousand gallons. I also add 1/2 to 1 cupful of Calcium Hypochlorite( diluted ) once a week if it is extremely hot, other wise I do not add it. Are you adding the clear??. Doing all this once a week has kept my pool almost perfect all summer. Are you using a solar cover?? I did have a algea problem when the water temp got to near 90 and I left the solar cover on, i added a little power 60, shocked and ran the filter 24hrs and it was clear in a day. Since I have taken the cover off I have had no issues. It sounds like all you need to do is add a little shock once a week with you daily routine, doing this should solve your problem.. One more question are you filtering enough??, you should be filtering 10-12 hrs a day if not more.
After reading the BBB system it is interesting, but I am too impressed with synergy at the moment to switch. If I should start to have a problem with it, I will give BBB a shot but not till then.
