Thread: Any reason not to run with a CYA of 90?
    30,000 IG
    FC 13
    PH 7.4
    ALK 90
    CYA 90
    My pool is in full sun and always has a water temp in the high 80's. The water is crystal clear. My numbers are always stable and I only add bleach once a week (big bottle of clorox). Chlorine level is always 13-15. Is there any reason to lower my CYA?
    Pool Type: Alantis 18 Ft Round, 52" Above Ground Pool
    Pump: Sta-Rite JQPA5E
    Sand Filter: Sta-Rite T-200BP-1
    Vacuum: Basic one that came with pool, and a Sta-Rite Lil' Shark
    Chemical Brand: BioGuard
    Jeremy
    Re: Any reason not to run with a CYA of 90?
    The two main disadvantage with this approach is that the PH tends to read a little higher than actual when FC levels are in the 13 to 15 range so PH is tricky to set exactly and if you ever did get algae it would take quite a lot of chlorine to fight the algae.
    I shouldn't get algae if I maintain the high chlorine level, correct? Or, am I flirting with disaster?
    Jeremy
    You shouldn't get algae, but sometimes something unexpected can let algae get started anyway. If you keep ahead of your pool, add extra chlorine before major storms or big swim parties, and don't leave it alone too long, you should be fine for a good long time.
    Very high CYA levels are making a trade off, more convenience day to day in exchange for bigger problems when something does go wrong.
    Thanks. I'll lower it a bit next summer. Also, I added 200 lbs. of salt to the pool....the best thing I've added since bleach. Really knocks the edges off the water.
    Jeremy
