My pressure gage reads 12
ethany
564
Trenton NJ
The pressure is low,usually around 20 plus. I backwash when it get in high 20s-30. I have good water flow, not finding any clogs. Cleaned out baskets. Sometimes I get pine needles in the impeller and I reach in and work them loose.
Everything seems fine except the gauge reads low. I even replaced the gauge. Still reads about 12.
I plan on closing this weekend so I'm hoping to get this fixed.
Thanks
Only way for the pressure to be lower than normal is a suction clog or a clogged impeller or a clog between the pump and filter or a bad gauge or something clogging the port to the gauge.
You might want to split the pump and do a better job inspecting the impeller ... would not be the first time pine needles clogged up the pump.
So I did split the pump......it was fine. Few pine needles but no obstruction. Put it back together and still low. Not sure what to do now
My sand hasn't been changed in over 5-6 years. Could that cause an issue like this?
Multi port.....Haywood sand filter. After cleaning pump n reassemble I'm getting 16, so at least it's a little better. I'm wondering if I should just close this weekend n blow everything out. See what happens next year. What do you think?
