- May 22, 2013
- 2,796
- Plaster
- Hayward Aqua Rite (T-15)
The two in the comparison come with Comet AXD pumps. http://www.pressure-washer-parts.com/comet.asp
Which pressure washer was it that came without nozzles ??
http://www.northerntool.com/shop/tools/NTESearch?storeId=6970&ipp=24&Ntt=electric+pressure+washers
Northern Tool does have a very good quality electric with a CAT pump, 2000 psi, 1.5 GPM and plugs into the wall in a standard outlet. They would like you to have a 20 amp circuit for it but that doesn't mean if you plug it into a circuit with a 15amp breaker it's going to blow. Just depends on if you have other things running on that circuit at the same time.
20 amp circuit breaker runs about $5 at home improvement store if you needed to swap it for a 15 amp currently on a circuit. Most garages should already be on a 20. http://www.homedepot.com/p/Siemens-...terchangeable-Circuit-Breaker-Q120U/100044919
The 240 volt version would take a different outlet. If you are creative and don't run them together you could share the circuit with a pool pump motor but having a dedicated circuit & breaker would be better. 3,000 PSI, 2.5 GPM and it comes with a CAT pump.
