Results 1 to 11 of 11
Thread: Found critter in pool, do I need to shock?
    Jun 2008
    Florida
    12
    I found a rat in the pool going for his morning swim this morning. So I scooped him out and tossed him into the woods in the back. Do I need to shock or anything like that? I did a quick search, and most people seem to think it's a problem only if the critter has been dead and sitting in the pool a while. If I don't need to shock, would it hurt anything to add some anyway? My wife is insisting we change our water lol, she's a little freaked out...I'm trying to convince her otherwise.
    14 X 30, 15000 Gallon
    In Ground, Gunite
    Built 1994
    No automatic cleaner (it broke)
    Using the Pool Buster Vacuum
    Mar 2008
    Roseville,Ca
    30
    Re: Found critter in pool, do I need to shock?
    What a coincidence.I found a mouse in my pool too this morning but it was not alive and assume floating for awhile.I have the same question you do.What do I do to the water?Should I be worried?
    Thanks
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    If it were me I think I would go ahead and shock the pool. In fact I know my wife would insist I shock the pool !! What could it hurt and at the same time it will give you piece of mind in the mean time
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Butterfly's Avatar
    South Carolina
    10,045
    I agree with TiZ!
    You're done SLAMing when:
    Mar 2008
    Roseville,Ca
    30
    If I shock today when can I swim?
    Butterfly's Avatar
    South Carolina
    10,045
    There are a number of opinions on this and therefore not a clear cut answer.
    IMHO, I feel that anything below shock level is alright. But other people set their line higher or lower than that.
    Wearing an older swimsuit and showering after would seem like a reasonable idea.
    Dec 2007
    Central New York
    504
    Alive rat, I would shock Monday when everyone is back to work. Don't worry about it.
    Raiderchuck .... sorry, but I would shock now. Dead is dead; there for you never know.
    My grandkids can go in the pool when chlorine is 10 ppm or less..... my two cents.
    A word of advice....... Never tell your wife or kids that you found anything alive or dead in or around the pool.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Nick's Avatar
    Jun 2008
    Bristol, UK
    36
    Putting the issue in perspective, rats and many other critters regularly swim in our reservoirs, springs, wells, streams and other sources of drinking water which we only treat with a mild dose of chlorine. Although it may not be a good idea to mention that to sensitive types of people.
    Intex 16'x48" AGP 5,000 (uk) gallons
    Intex 635 pump
    Bio Diesel filter bags
    4 solar radiators and a solar cover
    Mar 2007
    Coastalish 'down easter'
    4,160
    Pour bleach in, wait an hour and dive in (It'd really suck to get plague, just because you didn't want to spend a couple $ on bleach :P )
    Anything larger than a bug that's dead in the pool get's removed and chlorine added, any rodents or birds that are alive get evicted (possibly leathally ) and the pool gets chlorine - cute as some of these critters may be, they CAN carry diseases, so why take the risk - bump up the fc!!
    Happy swims!
    Luv& Luk
    -Ted
    Mar 2008
    Roseville,Ca
    30
    ok I ran the pump for 16 hrs and FC at 4.0(I have a SWG)
    who would swim in it if they found a dead rat that was in there for a couple of hours 48hrs ago?
    Dec 2007
    Central New York
    504
    I've swam in a lot worse water.
    I would go in now.
    Hotrod30
    Pentair VF3050 pump
