question about salt in a non salt system pool?
JayGee
Aug 7, 2008
36
I'm brand new here. I began looking to the simpler solutions to pool care, ie not through the pool store, and picked up what sounded like a good idea. I think I'd best check here and see if it is first.
I have (and it should be in the signature) a 24000 gal IG pool and use a cartridge filter. The water's clear and chemicals arent too bad. I'm still researching the site before bringing many questions. But I have one I want to bring quickly. Mainly because if I'm all wrong, I can still return the product. If this is the wrong forum for this, my apologies.
It was suggested that adding some salt to a pool would help prevent eye irritation and make the water "feel better." So I had picked up some water softener salt.
I just got a Taylor 2005K test kit but haven't finished reading the instructions yet.
My last (2 days ago) pool store water test gave numbers as follows:
Free chlor-4.0ppm (high & know. I just got off test strips and my last didn't read chlorine worth a darn I find out)
Total chlor 4.0ppm
combined chlor 0/0
ph 7.7
hardness 120ppm
alkalinity (w/stabilizer correction) 204ppm
CYA 20ppm This was much higher but I did water replacement to bring it down. I was still guaging by test strips until a couple days ago. It's a little low I know. Will some hocky pucks bring it back up? Btw, according to my new oto test kit shows the chlor still a bit high. It hasn't been dropping much. For the past couple weeks I have been using plain ole bleach.
One question specifically about the salt, assuming I want to go ahead with it, since the water 'hardness' is low, will 'softening' the water hurt anything?
I hope this is OK here and I haven't just stepped off the deep end?
Thanks all.
Hi JayGee! Welcome to TFP! :wave:
Um... hockey pucks don't add chlorine or CYA! :mrgreen:
I know what you meant... the pucks will add CYA, just be careful so you don't over use them once the CYA starts to rise but they will also lower pH because they're acidic. So just be careful like I said.
I have salt in my pool and it feels sooooo goood! I wish I'd of found it sooner!
Not the kit you want. You want the K-2006 which has a different chlorine test that can test up to 50 ppm FC with a precision as low as .2 ppm. If you can return the kit do so and get the K-2006! You may have to order it online. You can also get a TF100 from TF Test Kits. That is the kit tha most of us on here use. It uses Taylor reagents but it's a better 'bang for your buck"! See the Pool School article on test kits and the link to TF Test Kits in my signature.
Total chlor 4.0ppm
combined chlor 0/0
ph 7.7
The above numbers are fine for now.
hardness 120ppm
Too low....see the recommended levels section of Pool School! What is the surface of your pool? If it is plaster this is WAY too low. Ditto if fiberglass. For vinyl you are just a bit low.
Way too how. See the lowering TA section of Pool School.
Salt will not soften the water. A water softner uses salt and an ion exchange resin to soften the water. Adding salt to a pool will make the isoelectric point of the water closer to that of the human body and increase bather comfort but it has nothing to do with softening the water. You still need to add calcium to raise your calcium hardness. Salt will have no effect on this whatsoever.
Thanks all.
Hope this helps. Read Pool School. The link is in my signature.
We add salt to our above-ground pool to improve the water feel. The concentration is probably 1600 ppm, calculated. I've not tested for it. The salt we use is Morton's Solar Salt, 99.9% pure, no metals. I don't know if that's the same as water softener salt.
revstriker said:
What is the procedure for adding salt to a pool?
dump it in and let is dissolve.
How do you calculate how much to add?
Use the pool calculator...see link in my signature.
This sounds interesting, and something I might like to try.
Start with about 1200-2000 ppm
Yeah, i'd like too try that too if there's no negative impact. Would like to improve the feel, where did you get the solar salt? and I second the "how to" add it.
Home Depot, Lowes, Grocery Store, Ace, etc. It's for water softeners. You can use the pellets also but they take a lot longer to dissolve. You want the salt that is at least 99.5% pure with no additives for rust removal or cleaning the water softener.
Go to the Pool Calculator.
In the upper left input the volume of your pool. Scroll down until you come to SALT in the left-most column. Put 0 in the first box (you're starting with 0 ppm salt) and put 1200 in the adjacent box. Most of us who've added salt run a concentration of between 1600 and 2200 ppm. In our pool 1200 was enough. Hit the TAB key. The result will tell you how many pounds for the desired concentration.
We started with two 40# bags, then swam for a few days but didn't notice any difference. We added another 40# bag which gave us the desired effect: smoother feeling water, less skin drying, and it's easier on the eyes.
As to the method of adding the salt, there are many. Dump it in, swish it around with a brush, leave it to dissolve. Slit a bag open and drop the entire bag in, then stomp on the salt like you were stomping in a vat of grapes. That one is fun - dissolving salt is an endothermic reaction. The water around your feet will be colder.
If you scatter it across the pool on a sunny day, have your camera ready. The salt crystals will look like a horde of diamonds for a while, very pretty.
Once you have salt in your pool, it's in there. We make adjustments each season, based strictly on water feel. I have never tested for salt and couldn't tell you right now what our actual concentration is.
Here it is again:
Thanks for the welcome. I think I'll go ahead with the salt.
Calcium hardness. Is that the stuff the heats up in the bucket when you mix it with water? the pool store really reamed us on that stuff. Sold my wife a 25# bucket for $31 and told her to try it though we were probably going to need more. We did. When we went back they sold us another bucket. For $31. That's 50# for $62. Right? I look on the back wall and see 50# bags of the stuff for $32.
They don't get any more of our money!
But about this test kit. I'm in a bind now. I'm on a fixed income and literally can't afford the shipping return and new purchase. If I return this, I don't get another, not for some long while anyway. Maintaining the pool is a burden, but the wife & kids get so much pleasure from it and it is supposed to be 'good therapy' for me so we keep it going.
Can it (K-2005) be made to work or suffice in the absence of the newest and best?
Take the buckets back and that should pay for a TF-100 if you kick in a few bucks. :mrgreen:
The DPD test is just not going to cut it in the long run. One solution is to add the FAS-DPD test to the kit. You can buy the FAS-DPD test from TF Test Kits, it's not that expensive.
Realize that a good test kit is NOT a luxury item but an essential piece of pool maintenance equipment. It will pay for itself in no time in money saved on unnecessary chemicals.
Thanks! I'm going to go ahead and give this a try!
I follow you. I'll look up this FAS-DPD thing. I'm not your usual pool owner. We bought this place when I was a machinist making good money. That's past history. today I'm disabled. We gave up some things to get this kit. I did research just did it badly apparently. But now it's a case of a pool test kit or my wife's 6 years overdue eyeglasses. So now it's just muddle through with what we have just as we do in so many things. One has to wonder, what did they use before the K-2006???
More questions...
I have read elsewhere that calcium hardness is not that essential to a vinyl lined pool. Your opinion? I ask because you note that I need to bring mine up.
I also read that bring the PH below 7.2 in a vinyl lined pool is not a good idea yet you suggest I bring it to 7.0.
I am not trying to be adversarial here though I realize it must look that way. Rather, I have an inquiring mind and am trying to understand conflicting views.
They did dilutions to test high chlorine levels and wasted a lot of chemicals when it was not necessary. I would suggest keeping the K-2005 but adding the FAS-DPD only test from TF testkits.
More questions...
If you are already above about 130 to 150 ppm you are fine! You can probably ride it out at 120 ppm but 150 would be better. Believe it or not the cheapest way to buy calcium is usually the 50 lb bag. It often will actually cost less than a smaller size.
For extended periods of time this is true. If you are dropping the pH to lower TA then the pH iwll start rising once you start aerating so it's pretty much a moot point. You DO need to get your TA down!
Asking questions is how one learns. Your questions are good ones!
BTW, as far as eyeglasses go I buy mine on the internet and save a LOT of money. Zenni Optical and LBW Eyewear are both sites I have had good luck with (and I wear progressive lenses and have a strong prescription). I can buy 5 pair of glasses for the same price as I can get one from the local optician. There is an interesting forum about buying eyeglasses online you might want to check out. http://www.glassyeyes.com
There are review of the major online retailers and I highly recommend it!
Thanks much Waterbear. I learned the lesson about calcium stuff when the pool place sold us one 25# bucket for $31 noting we might need another, then sold us another when we did for a total of $64. It was then I noticed the 50# was only $32. I'm still royally POed about that!
I'll let the hardness ride untill next month.
I take your point on lowering the ph only briefly. I just checked today and the PH is down to 7.0-.2 and TA is 150 so we aren't doing too bad.
Thanks for the tip on the eye glasses. But my wife's eyes are really bad and a bad pair could literally blind her. We simply cannot trust an internet provider.
have a cateract in one eye, very strongt minus prescription in both eyes and quite a bit of astigmatisim. I wear either trifocals or progressive lenses and cannot see at all without glasses. I refuse the pay the $500 or more that it costs for one pair of glasses at the optician anymore when I can have my prescription made in photochromatic progressive lenses for less than $80 and find out that they are actually closer in spec to my prescription than the ones from the optician. I think your fears are misfounded.
At least research it ia bit, You will find out that the eyeglass industry is more corrupt than the pool and spa industry and that much of it is owned by Luxotiica (from eyeglass frames to lenses and labs to insurance!) I have been wearing glasses for almost 50 years now and can remember when they were not expensive items. The price skyrocketed about the same time Luxoxottica started biuying up everyting from frame manufacturers to LensCrafters and Pearle Vision!
