Cleaning pump strainer
coog61
Nov 6, 2009
89
Richmond, TX
When cleaning the pump strainer, after the pressure on the filter drum is bleed, most the debris runs back toward the pool. Then after filling the basket with hose water and restarting the pump, the debris flows back into the pump strainer. Any tips on how to collect this stuff?
Sent from my iPad using Tapatalk
There is not reason to drain the filter or open the air valve. Just take the pump lid off and lift out the basket. If you are quick, then most of the debris should not flow anywhere.
