I have the new K-2006 and I failed pool chemistry
I do apologize, how often should I add and test I thought I should not add Bleach during the day?
8/21 730pm
FC 1.4
CC .08
PH 7.0
base 2 drops to 7.4
TA 70
CH 110
CYA 20 this is est. due to the kit stopping at 30
SI -.9
8/22 730am
FC 1.2
CC.04
PH 7.0
base 2 drops to 7.4
TA 80
CH 120
CYA 20c this is est. due to the kit stopping at 30
SI -.8
8/22 730pm
FC 1.6
CC.06
PH 7.0
base 2 drops to 7.4
TA 80
CH 120
CYA 25
SI -.8
There is nothing wrong with adding bleach during the day.
Test and add bleach as often as once per hour.
If the water is murky, sounds like you need to follow the ShockLevelAndMAINTAIN Process before you get the SWG dialed in.
Re-iterate need to SLAM (post #12), strongly suggest you re-read the article.
1) I would suggest switching to a 10ml sample for the FC/CC test, each drop would count as 0.5ppm, it saves reagent and is precise enough
2) I believe you might have made a typo with the CC numbers, can you please confirm?
Abigail: I'm Glad you have corrected my thinking on the day time bleach I have always thought you should not add during the daytime, That the sun breaks it down I feel silly now. With the CC test I multiplied the drops by 0.2 using the 25ml test
FC 12
CC 0.6
PH 7.4
TA 80
CH 150
CYA 50
Epro5: the hardware store I use sells a lot of Chlorine so I assume it is fresh 2/1/2 gallon Jug 10% $4.59
