Results 1 to 7 of 7
Thread: New pool, local water alkaline, how to get CYA?
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    The AGP construction project continues- hopefully it finishes this weekend. I printed out poolschool articles and have read them repeatedly. My local water is alkaline- Ph 7.6-7.8, TA 80-90, CH 70 with a minor amount of chlorine in it TC=4. This is using a TF100 pool test kit.
    Now, it is burning hot here in Texas, and the pool will be in full sun most of the day, and I am going to be aerating to cool the water with a fountain (water is coming out of the tap at 85 degrees), and the water evaporation rate is very high (my friends in this area go through a lot of water, even with inground pools), so I gather that, unless I get some CYA in the pool, I will go through a LOT of chlorine.
    I have a 25 lb tub of 65% cal hypo granules for shock, and I understand about using bleach as a regular chlorine source, but I am a little vague on how to get the CYA in there. I gather I can go to the pool store and buy CYA, but I have also read that I can use di-chlor or -tri-chlor, which will add some CYA along with chlorine, as well as bring down the pH and TA some. I also have in hand 2lbs of 99% Sodium Dichlor-s-Triazinetrione from the pool store. I was told that I should add that at starting the pool at a dose of 1lb per 10,000 gal. Does that sound about right? Do I mix that in water and pour into pool with the pump running like I would cal-hypo, or add into skimmer?
    I understand that I do not want to make a habit of di-chlor or tri-chlor to avoid overdosing on CYA, (same as I do not want to overdose on cal-hypo, I just want use up the tub that the pool store talked me into) but it sounds like di-chlor might be a good way to get started to get a balance. Does that make sense? I am not excited about the whole adding muratic acid thing- sounds pretty scary.
    I had originally planned on starting with PristineBlue but between reading what is here on TFpool.com and reading the PristineBlue support forum, I am thinking about seeing if the pool store will take it back. So now I need another plan. I am thinking about SWG eventually, because the ideal TA and ph levels are closer to my local water supply, but until I make a decision to expend that money, I need to know how to start my pool on the right foot so that I can swim right away and survive a rough summer. Please help?
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Jul 2008
    South Eastern PA
    40
    Re: New pool, local water alkaline, how to get CYA?
    In your shoes I think I would start out with dichlor as well, as that will bring down your PH down, your CYA up and of course the FC up.
    I would also bring it to shock level to start out just to kill anything that may already be in or have blown into the pool. Working with 20,000 gal, 0 CYA, and 4 FC then 2 lbs of dichlor should get you to your shock level of 10 (Chlorine/CYA chart for reference). It will also bring your CYA up to 6 and your ph down by .25.
    Also, I would keep an eye on the the PH because as you already know dichlor is acidic and the PH will move downward to the lower end of the range after just a few doses of dichlor. You may want to make sure you have either some borax or washing soda on hand to bring the PH back up if it becomes necessary.
    The Pool Calculator really is a handy tool if you're not already familiar with it.
    8200 Gal Vinyl 18' AG Vogue Pool
    150lb Hayward Sand filter with 1-1/2 HP Maxim Pump
    Intex SWG
    Some of the most helpful links for pool owners: Pool School | Pool Calculator | The best test kit | Chlorine/CYA chart
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Hmm, I can see my signature, I wonder why you cannot:
    28 foot round Doughboy Sand Dollar II AGP,
    Expandable liner sunk into ground: 20,000 gallons approx
    1.5 HP Doughboy Power Pak II filter
    19" Media Master Sand Filter
    Pool installed in August (we hope) during 100 degree plus weather
    Jul 2008
    South Eastern PA
    40
    Yeah, sorry I overlooked it the first time. I just edited that last post, but you had already beat me to it.
    Intex SWG
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Thanks, any thoughts on how to add the dichlor? It is fine granules, like sea salt.
    It is best to pre-dissolve the dichlor in a bucket of water and then pour that slowly in front of a return jet.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Thank you JasonLion- what do you think about using the dichlor as an initial onetime startup/shock as I described in the first post?
