Re: Adding CYA
You shouldn't be starting new threads for each question, they're all related, so it would be helpful to keep them all in one thread. Post your most recent test results, and how they were determined. Yes, you need some cya or you'll not keep up with the FC requirements. As soon as you put the bottle of muriatic acid down, put in the cya to get you up to 30 to get started, up to 50 as you get better control of your pool. All-in-all FC is the most important thing for you to get right. Use pool math to get you where you need to be. TA is the last thing you need to work on. Hope you have an adequate test kit-- that's uber important!
