HELP - Low pressure and I'm stumped!
Jun 23, 2014
19
Falls Church, VA
I am stumped as to the reason for my low pressure.
Here is the story:
I have a 16K IG, with a Hayward super II pump and a hayward 48sq ft pro grid DE filter.
My filter pressure used to run at 15-18 PSI, but this season I cant get it to move off of 10 PSI. Clean or dirty filter, it stays at 10 PSI (though it drops to 0 if the pump is off)
Here is a run down of what I have done:
-Drain king-ed on the suction lines
-Blown air on the suction line
-Tried, unsuccessfully, to auger the skimmer lines.
-Disassembled, inspected, lubed and reassembled all 3 way valves
-Cleaned and inspected the impeller and diffuser
-Replaced the pressure gauge
-Replaced the manual air relief assembly
-Replaced return eyeball fittings
-Replaced pool pump motor
-Replaced all seals on the pump
-Replaced the spider gasket on the multi port valve (it was making noise and so I thought I would give it a shot to see if it helped)
So now I have no idea what could be wrong, my only thoughts are that I could have improperly reassembled the filter when I cleaned it last winter, or that the impeller is just worn out?
Any help would be greatly appreciated!
Poolbie
I will backwash the filter (hasn't been done in a while) and let you know what the outcome is. That said, last time I did it did not move the pressure gauge much, if at all.
I have not noticed a major change in the flow rate, however it was season to season and I dont have a definitive way to determine the flow rate.
In your first post, you indicate that psi stays constantly @ 10 regardless of anything else.
But then, in your last post, you indicate you have backwashed perhaps more than once. Why are you backwashing? Maybe we can get this figured out.:D
You raised the question of IF you reassembled the filter properly. :scratch: IMHO - If there is any doubt that is the place to go and recheck your work.
I know these are basic questions but need to make sure the basics are covered. Some people don't know DE needs to be added after backwashing. :roll:
Did you recharge the filter with DE after taking it apart last season and are you sure you're adding enough for your particular filter ??
Do you add DE after backwashing ??
duraleigh,
I missed your question until I reread the thread. To answer your question, I decided that after a month plus without any change in pressure that I should backwash anyway to ensure that the pool was still getting cleaned. Was this not a good idea?
Poolbie
Some people can go a year without the pressure significantly rising.
Did the water look like it was being cleaned? Maybe you just do not have much dirt load in your pool. :scratch:
I am failing to see an actual problem other than you seeming to recall the pressure used to be higher last year. Were there any changes to the pump or plumbing?
Jblizzle,
You bring up an interesting point. The only reason that I expect it to be 15-18 PSI is because the pool guy I paid to do the inspection when buying the home told me that it was supposed to be that way. I am not sure that after the first season (when I first disassembled and cleaned the filter grid) it went back up to that level.
Is there a way to calculate the proper pressure based on pump flow, filter size and plumbing size?
As for the backwashing, this also goes back to the first season, where I was backwashing every month or so.
As for the changes to the plumbing, I have only changed the eyeball fittings and added some unions so that I can remove the pump during winter.
Poolbie
Because every installation is different I don't think you can calculate your way there. The easy way is to backwash your filter throughly and then to note the "clean" pressure and to backwash when the pressure rises 20-25% above that.
Backwashing often without waiting for the pressure rise can be counter productive as a completely clean filter isn't as efficient as a slightly dirty one is at filtering as the dirt itself helps trap smaller particles. That's the whole idea of adding a little DE or DE substitute to a sand or cartridge filter to improve it's performance. You are actually plugging it up a bit with the addition. http://www.troublefreepool.com/content/133-add-de-to-a-sand-filter
Maintenance and cleaning of pool filters. :lookhere: http://www.troublefreepool.com/content/144-maintenance-and-cleaning-of-pool-filters
Good to know it might be the advise you received that's throwing you instead of you having a physical problem with the filter ;)
MBG75, he's not complaining about 10psi being low, he's asking why it doesn't rise like he thought it should.
Any chance your pressure gauge has failed? Goes up to 10, falls back to zero, maybe it won't go past 10.
Thanks for the thought, but I replaced the pressure gauge first thing. I actually have another one sitting in the shed, it may be worth giving it a shot.
Thanks to everyone for your thoughts! My plan for the time being is to show some patience and see what happens the rest of the season.
Poolbie
