Hot tub draining back to pool
I REPLACED THE CHECK VALVE BUT IT STILL LEAKS BY WHEN THE PUMP IS OFF. I CAN CLOSE A MANUAL VALVE AND STOP IT BUT WHEN PUMP COMES BACK ON THEN MY SPRAYERS COME ON TILL i GO OPEN THE VALVE. I ONLY PUT A NEW FLAPPER NOT THE WHOLE VALVE BODY.
WHY ARE YOU YELLING AT ME!?!?!
:wave: Welcome to TFP!!!
If you can close a valve and stop the draining, then it seems like you have isolated the problem. The check valve or a 3-way valve must still be leaking.
