Thread: May have used more 20 Mule Team than I really needed...
    Carrollton, TX
    113
    Got my borate strips today and water tested less than 10ppm. Added 3 boxes to pool, then compensated the high pH with acid. pH is fine now but borates register closer to 80 than 50 - maybe around 65 - 75.
    Pool size is just shy of 7,000 gallons. Will this cause any problems?
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Having your borates around 65-70 shouldn't cause any significant problems.
    I don't think your test strips are reading accurately. I calculate that increasing from 10 to 50 in a 7000 gallon pool would take 20.6 pounds of borax. A box is 4 3/4 lbs, and three boxes is 14 1/4 lbs. Three boxes should have increased your borates level by 28 ppm but your test strips showed an increase of 55 or 60.
    Guest
    It will take about 21lbs of borax (just under 4.5 boxes) to raise 7000 gallons to 50 ppm from 10 ppm. and will need about 1 gallon, 1 qt. and a cup of acid. This is for the decahydrate (20 mule team).
    For the pentahydrate form it will take 18 1/3 lbs and require 1 gallon, 1 qt. and 3/4 pt. of acid based on the dosing charts for Proteam Supreme.
    Carrollton, TX
    113
    Thanks for the replies. I tested again this morning and reading was about 40ppm. Maybe I tested too soon after adding borax initially.
    I don't know if it's just me but the water seems to feel even more silky than with the salt alone. Water looks beautiful!
