Intex Pool Setup Done!!!!!
Jun 22, 2008
18
Well actually it's been up for a little over a month but I have finally gotten out of it to post some pictures. It's the 18' x 48" frame set. Everything went pretty smooth except for the cheap intex pump it came with which I already knew wouldn't last. I changed it out after 2 weeks to a Sand Filter setup. I was worried after hearing all the plumbing issues on here but I had none. Water has been crystal clear from day one. I'm using the BBB method and the TF100 test kit. My only regret now was not buying a larger more permanent pool. There's always next year I guess. Only thing left now is to finish the outside perimeter. Thanks for all the great info on this site.
[attachment=2:1rn74z37]IMG_0487.JPG[/attachment:1rn74z37]
[attachment=1:1rn74z37]IMG_0491.JPG[/attachment:1rn74z37]
[attachment=0:1rn74z37]IMG_0494.JPG[/attachment:1rn74z37]
[attachment=2:31btqm2y]IMG_0499.JPG[/attachment:31btqm2y]
[attachment=1:31btqm2y]IMG_0536.JPG[/attachment:31btqm2y]
[attachment=0:31btqm2y]IMG_0531.JPG[/attachment:31btqm2y]
[attachment=2:d0fcnal7]IMG_0532.JPG[/attachment:d0fcnal7]
1 1/2'' Slip Coupling to Adjust Skimmer when needed. 1 1/2'' to 1 1/4'' reducer allows the stock skimmer to pop right in. I can pop it out and attach my new 1 1/4'' hose very eaisly.
[attachment=1:d0fcnal7]IMG_0534.JPG[/attachment:d0fcnal7]
Added fountain to cool down the water
[attachment=0:d0fcnal7]IMG_0535.JPG[/attachment:d0fcnal7]
4" to 2'' Reducer, 2'' Street 90 Degree Elbow
[attachment=1:1rza8dbr]IMG_0537.JPG[/attachment:1rza8dbr]
Crystal Clear Water :wink:
[attachment=0:1rza8dbr]IMG_0530.JPG[/attachment:1rza8dbr]
Actually it's 30# Roofing Felt Paper. Several posts i've read mentioned it for use in AGP setup. Being a roofing contractor I had a few extra rools laying around :wink: .
I'll try and take some photos tommorow of the fountain running.
Nicely done. My setup is fairly similar.. I used regular weed block under the sand and I have a small, mulched flowerbed w/ a natural rock border around about part of the base. I also have a small deck around part of the pool. I do have an unfinished part around the base and my equipment area needs a little bit of "finish".. I wish I'd thought of the roofing felt. That's an outstanding idea.
What kind of fittings did you use to go from "Intex plumbing" to regular PVC? I have a smaller version (15'x42") of the same pool and I'm thinking that I'd like to hardpipe my setup.
