Thread: Test kits
    Mar 2008
    League City, TX
    144
    Test kits
    We are nearing the end of our pool build so I'm starting to think about water testing. The PB includes a Taylor K-2005 test kit but in pool school it recommends the Taylor K-2006 kit. What is the difference? Is the K-2005 a good kit?
    Pool completed in the fall of 2008.
    Landmark's pool build
    Freeform 26' x 45' IG gunite, 4' to 8' deep, 29,500 gallons, WetEdge PearlMatrix Tropical Mystic, Freeform 8' X 11' Ultimate 16 jet spa, 38' moss rock weeping wall and 3 waterfalls,
    4 pumps (Intelliflo 4X160 filter pump, WhisperFlo 3HP spa pump, Pentair 2 1/2HP WaterFall pump, cleaner booster), EasyTouch 8 controls, Quad DE 100 filter, MasterTemp 400K heater, Pentair Legend Platinum cleaner, 995 sqft. Sundek.
    Re: Test kits
    The Taylor K-2005 is a good kit in every way but one. The K-2005 includes the DPD chlorine test, which only measures FC and CC levels up to 5 (or 10). The K-2006 includes the FAS-DPD chlorine test, which measures FC and CC levels up to 50.
    If you are getting a K-2005 included, all you need to do is add on a FAS-DPD chlorine test. TF Test Kits sells the FAS-DPD test individually, as do a number of other vendors.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Re: Test kits
    Per instructions 5217 for Taylor FAS-DPD Chlorine Drop Test (1 drop= 0.2 or 0.5 ppm) you need:
    5217 Instructions
    9198 Sample Tube, Graduated, 25 ml, plastic w/cap
    R-0003 DPD Reagent #3
    R-0870 DPD powder
    R-0871 FAS-DPD Titrating Reagent (chlorine)
    The K-2005 should contain the sample tube and reagent #3, the instructions you can get from Taylor
    http://www.taylortechnologies.com/pr...er&Number=5217
    if you add R-0870 and R-0871 you should be all set.
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    Mar 2008
    League City, TX
    144
    Re: Test kits
    Thanks for the information. I've never owned or maintained a pool before so I'm really nervious. But I'm sure I can do it with help from all the knowledgeable and friendly people on TFP.
    Guest
    Re: Test kits
    Quote Originally Posted by New2Me
    5217 Instructions
    R-0870 DPD powder
    The K-2005 does not have the sample tube but you can use the pH/TA/CH tube for this test. However, the FAS-DPD test might cause it to get some slight discoloration over time.
