Thread: remove this auto cleaner before shocking... what FC level?
    Bubba17's Avatar
    Jun 2008
    Pinehurst, NC
    14
    The instructions that came with my new automatic pool cleaner say to remove it from the pool before shocking. What does this mean for plastic and rubber parts? We all know that your shock level depends on your CYA level. If I ever have a huge algae problem again and shock it properly, I would of course remove the cleaner while the FC is really high, but when can I put it back in the pool to start cleaning up?
    Do I assume this means the generic answer of 10 FC, or can I use the "safe to swim" level of 40% of CYA?
    Thanks!
    27,500 gallon inground vinyl
    TF-100 test kit
    sand filter
    chlorine
    Dec 2007
    Central New York
    504
    Re: remove this auto cleaner before shocking... what FC level?
    I don't know what the right answer is but I'll tell you what I do. My pool cleaner only goes in the pool when the chlorine is in the safe to swim range. I will use the manual vacuum when I have the chlorine in shock range or my Spring super shock range. The manual vacuum head is cheaper than most parts of my Ray-Vac. Just my 2 cents.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jun 2008
    Houston, TX
    68
    Good question...wish I had an answer. I always leave my Polaris in the pool when I shock. I didn't know I wasn't supposed to.
    Pool Specs:
    16,000 gal. IG - Plaster - Auto Chlorinator
    FNS 48 DE Filter - 2HP Centurion Pump (A.O. Smith)
    Hayward HeatPro Heat Pump - Polaris 360
    Guest
    I have very rarely ever had to shock but when I have I take the MarsHP out and wait for the FC to drop below 10 ppm before putting it back in.
