My First Tests
You're late with both pH and FC adjustments.
Not embarrassed to say I probably will need a little hand holding in the beginning...
First, lower the pH to 7.2ish, re-test to confirm, then add enough bleach/liquid chlorine to reach 10 ppm FC.
Based on CYA of 80, keep the FC between 6 and 11, and never below 6. Hop to it :wink:
Thank for giving me numbers to match! Running new tests to put into the PoolMath page right now.
It's been about 12 hours since I put in the muriatic acid and chlorinating liquid. I'm test FC and pH now, is that an acceptable time period to wait?
Half an hour is usually plenty of time for things to mix before you retest. But since you weren't off the scale, if you added the correct amounts, there's no reason to check again so soon. Once every 24 hours is plenty.
Thanks Richard! I did edit my post to reflect the tests that I just ran. I'm starting to understand more how to find info on the site and what to look for in the test results. The Recommended Levels and Chlorine / CYA Chart pages made things a lot clearer last night...
I'm finally having fun with testing and seeing the results! :rockon:
I've been keeping my FC around 8 and shooting for 9. My pH was less than 7.8 but not quite the same color as 7.5 yesterday.
With my CH being so high is that why the water is cloudy when I'm swimming with my eyes open and no goggles?
If the recommendation for lowering my CYA is to drain 50%, which won't be done due to water restrictions, then how long will it take for Nature to drop this?
Thanks everyone for the help!!!
You eyes are not designed to focus underwater with no goggles, so it always looks cloudy/blurry. The CH should not impact the clarity.
The CYA will only drop when you physically remove water. So how fast that happens I suppose depends on the amount of rain that you get and thus have to pump off water.
I guess it is good then that I live where there is no rain... :scratch:
Then it is going to take a LONG time for nature to lower your CYA.
I read this in the ABCs: "If you have a SWG or very high levels of direct sunlight, CYA is typically kept between 70 and 80." I am in Southern California and my pool gets quite a bit of direct sunlight. With that said am I ok with my CYA staying around 80?
My wife and I should probably be thinking of re-plastering and that would obviously mean the pool needs to be drained. Maybe this winter if we can "afford" to we'll re-plaster, put in a SWG (she read about this and now wants one), and a gas heater...
Thanks for the continued answers/help!!! I love TFP :cool:
CYA level of 80 in a non SWG pool is doable. You just have to maintain a higher FC range for it.
Your FC levels should be a target of 10 and never let it fall below 6. You don't want an algae outbreak with high CYA levels. The shock level is 31. Takes whole lot more bleach to get to that FC level. ?
