Thread: Intex skimmer box ... questions
    We have an 18'x48" Intex Metal Frame pool. It came with a skimmer box that is mounted to the side of the pool. The pump is mounted on the bottom of the container.
    My question is that I want to remove this pump and connect up hoses for a larger more powerful pump that I have (the 2500gph model). Has anyone done this and if so how did you do it ... ie did you just drill out the bottom for the fittings?
    Please lmk thanks
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Intex skimmer box ... questions
    Can you post some pictures?
    Does your filter look like this?
    If your filter is like this, then I would reccomend buying a "Real" filter(not Intex) and buying the Intex skimmer. Although, I don't believe a brand new Intex 18' pool would come with that filter. They usually have a filter that sits outside the pool.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Nope it's attached to the pool and is tall with cartridge inside and the pump is on the bottom.
    I will try to shoot a couple of pics tonight.
    My hope is that I can remove the pump from the bottom, drill or cut out the area where the pump attaches (it has plastic pegs sticking out to hold the pump in place) so that I can put PVC fittings on it to then attach my lines to the the larger pump.
    My only real concern is that I the plastic will simply crack and split and then I am screwed.
    I have looked around for another skimmer box that attaches to the pool wall that I can buy to use instead but none of the ones I have found so far have the same size opening and screw mounts.
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
