AGP construction has begun today!
Jun 27, 2014
58
Boston, MA
I'll post pics as the day goes by. Installers are here and unloading the boxes. Electrician doesn't come till Saturday morning though. Do I bother adding chemicals and trying to manually mix? I'm sure it's going to take a while to fill though.
Uh oh, says I exceeded my quota...can't upload more photos
Good luck with your install !
What will be your water source for your fill ? You can add some bleach to get your FC up to 2-3 and mix it with a pole brush. That should hold ya till you get the pump running. With zero CYA it'll burn off from the sun in a day. After your pump is going then start to get things balanced. PH, FC, CYA.
Forgot to ask, do you have one of our recommended test kits ?
