Results 1 to 8 of 8
Thread: pump leaking
    pump leaking
    I've replaced the electric motor on my pump and it is leaking.
    Does anyone have and idea how to stop this?
    36,000 IG Vinyl, Aquarite Salt Generator, Sand Filter, Hayward 1 1/2 pump
    Apr 2008
    Central Texas
    326
    Re: pump leaking
    If your pump is like my Challenger, there is a ceramic seal behind the pump impeller that only works when installed correctly. If it is reversed it will leak. I replaced that seal with a new one when I put new bearings in my pump a couple of years ago. Alas, I can't recall offhand which way the ceramic end is supposed to point. But you have a 50-50 chance that it went back on backwards.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Re: pump leaking
    Thanks.
    I have a Hayward pump. It is leaking between the motor mounting plate and the pump seal plate.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: pump leaking
    I think Harry got it right, the shaft seal assembly (# SP 1600 Z 2 for super pumps) there is also the chance that the housing gasket (SP 1600 T) is too worn or has failed. Getting the seal assembly changed ASAP will help the motor last longer!
    If you need any 'nuts and bolts' info on changing them, I think I've got it posted here somewhere, or I can just retype the info
    Good luck with this! Please keep us posted on how things are going
    Luv& Luk
    -Ted
    Re: pump leaking
    I'm not sure what you mean by housing gasket. The dffuser gasket seams worn.
    Jul 2008
    Pittsburgh, PA
    118
    Re: pump leaking
    The diffuser gasket shouldnt cause leaking. He is refering to a SPX1600T. You will see that gasket if you remove the four 9/16 bolts on a superpump. It should be well seated along the rear of the housing and should not be excessively flat. Try putting some silicone lube on it when you reassemble the pump if it looks worn.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Re: pump leaking
    Thanks. Other information helped tremendously. Pump is now working without leaking! Thanks again!
    Apr 2008
    Central Texas
    326
    Re: pump leaking
    Quote Originally Posted by eaglesflying
    Did reversing the seal fix it, or was it something else?
    Polaris 280
