View Poll Results: Add pea gravel to sand filter base
Voters
21. You may not vote on this poll
  • Yes
    8 38.10%
  • No
    8 38.10%
  • Undecided
    5 23.81%
Results 1 to 9 of 9
Thread: Sand filter...add pea gravel base or not?...Poll
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    I'm going to set this up as a poll to see what the consensus is on this matter.
    Where would I find this pea gravel?
    I've read through alot of older posts on this matter and just want to see what everybody else is doing.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Mar 2007
    Morris, IL
    477
    Re: Sand filter...add pea gravel base or not?...Poll
    I voted undecided, although I would probably go ahead and do it, possibly to a depth of 3" over the laterals approximately. I like the idea of keeping the sand away from the laterals, and feel that it could go a long way towards keeping the sand from going through the return. If I ever need to replace my sand, I will probably go ahead and do that.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Does anybody here know what type and size of pea gravel I'm looking for if I decide to go that route.
    Does it look like this?
    This is "Long Island" pea gravel
    Thank you TFP
    Not in small residential filters. In large commercial filters it is needed to support the weight of the laterals.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by Aquaman95
    Now that makes alot of sense to me.
    I think you mean to support the weight of the sand...no?
    But nonetheless a very good answer.
    So now I'm thinking this issue is irrelevant to my size of filter, although 150#'s of silica sand sounds pretty heavy to me.
    Thats just I bit more than I weigh
    Thank you TFP
    Dec 2007
    Central New York
    504
    If I were you with 150# filter, I wouldn't add pea gravel.
    My filter is 350# and I added 80# of pea gravel. Since the filter, pump were new and I replaced all the pump house 1.5 inch piping with 2 inch piping, I couldn't say if it improved or not. I'm happy with what I have.
    I read once that you should use pea gravel for swimming pools. I never found that stuff so I used pea gravel from Lowes and started the filter on backwash and rinsed for awhile. JMHO.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    The Pentair Triton II series suggests the use of pea gravel. They start at 175 lbs of sand.
    Mar 2007
    Coastalish 'down easter'
    4,160
    I believe I was the first one to vote "YES" - but didn't realize I could add to the post
    The gravel serves a couple purposes:
    #1 Increases flow around the laterals
    #2 Keeps sand out of the pool if a lateral breaks
    The filtration is primarily carried on in the top part of the sand, so a few missing inches of 'fine' filter material doesn't make much difference and the added flow around the laterals makes up for it (IMO)
    Luv& Luk
    -Ted
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by waste
    Those sound like definite pluses to me, the other plus is that I can get whatever kind of gravel I need for free
    Thank you TFP
