Thread: Intex 2500GPH Pump/Filter
    I have just receive my pump/filter from ebay and have to say I was extremly happy to see it. Got it home and proceded to take it out of the box and start hooking up and then my day just crumbled , I didnt get the adapters like I was suppose to.
    I have a 16x48 intex pool from Sams( Great Deal). I was wondering if these adapters were something that I could go to Home Depot or Lowes and purchase? Or is it something that I have to get from intexcorp.com? This always happens to me.
    Also thanks for all the great advice that you guys have given me, my pool is now perfect
    Misty
    10k gal. IG vinyl, 1 hp pump, 200 lb sand filter, solar panels & cover
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Intex 2500GPH Pump/Filter
    I'm pretty sure the adapters are specific to Intex. If you're handy, you can probably go to one of the big box stores and find the fittings to make it work, but they won't be the exact adapters you need.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Sounds like you need these
    And these
    I ordered my adapters from Intex and they shipped in 2 days, I already have 4 plunger valves.
    You can get them on Ebay too, but they'll cost alot more.
    Good luck
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Thanks for the replies,
    I ordered the adapters from Ebay for about 20.00 they should be here in a couple of days.
    I needed the second picture, I already have the first ones, they came with the pump.
    Cant wait to hook it up.
    Thanks again
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Also of note....
    If your pump came with the white hoses with collars and your pool has the clear hoses.
    You can just hose clamp the clear hoses to the white ones to get it going for now until your adapters come in.
    Thank you TFP
