chlorine acid vanish, CYA vanished, bad pH reagent and non-ergonomic spoon
engrav
Platinum Supporter
563
Whidbey Island, WA
Hi
Am following TFP advice and pool is fine and pretty much matches PoolMath.
FC 5
CC 0
pH 7.6
TA 80
CH 250
CYA 30
But it soaks up chlorine and acid like a sponge. Am using 5.25% bleach from local hardware.
So set out to find stronger chlorine and found the HASA web site
<http://media.hasapool.com/productpages/P-1.pdf>
seems like an Ok company
where I see recommended
FC 1.5 to 3
CYA 60 to 80
the TFP chlorine/CYA chart shows at 60 CYA a min FC of 5
so am confused? how to explain the different recommendations?
Thank you
Re: confused about HASA web site info
A large number of companies publish recommended levels that date back 60 years or more to the time before anyone knew what CYA did. These outdated recommendations just get copied from place to place, and no one ever bothers to update them to actually work with CYA.
thank you, I suspected same
so then
is there any way to reduce the powerful suck of chlorine and acid
to reduce it from 1.5 gal 5.25% bleach and 1 pt acid / day
or
is that just the cost of doing business in the summer, the cost of enjoying grand baby giggles
so then
or
That's a BIG pool. 2.5 gallons of 5.25% is only 2.7 ppm/ day chlorine. That's not bad if the pool gets a lot of use
You shouldn't need to add acid daily (weekly), and chlorine is a daily chore, but looks like you have a SWCG, so that task should be done automatically. With a SWCG you should have a higher CYA level (70-80).
as above, Ok a BIG pool and it will suck up stuff, got it; so must figure out how to avoid ≥45 empty bleach bottles / month; will search for a 12.5% bleach method
but I do need to add acid all the time; diary shows I added acid 6/26 6/28 6/30 7/2 7/4 and 7/7 (I guess not quite daily)
SWCG? do not have that; if something wrong in my signature I should fix that
With only 30ppm CYA, you will be losing a lot to the sun. Try raising it to 40ppm and see how it behaves.
read "The ABC's of Pool Water Chemistry" up in Pool School.....all those answers are there. I will add that chlorine consumption is driven by two things ONLY. UV on the pool water and organic materials in the pool water. There is NOTHING else that consumes your chlorine and a principle that many of us "seasoned" pool nerds" often forget
Hi
Have read it many times and in accord, moved from swamp with two dead rats to a pristine beauty (IMO)
Have now moved from how to fix to how to reduce the acid/chlorine burden; cannot process 45 empty bleach bottles each month
I like Richard320's signature
Richard320 said is a BIG pool; ok then gotta just suck it up so to speak
JohnT said bump CYA to 40; could do that
several have said get higher % chlorine; could do that
jblizzle said test OCLT at higher FC; could do that
ABC says high TA cause up drift of pH but I do not have "high" TA
but then 257WbyMag said in another thread let TA drop to 70 or 60; could do that
there is a Rainbow turned off; could drop in a tab or two
so will try all these tweaks thank you but
after I jump in tomorrow to remind myself why I am doing this
My pool is 44k gallons. If you are on the bottle (bleach), you might consider going salt. Buying bleach and daily maintenance of a large pool takes a lot of effort. Standing by the pool and adding the bleach might not be that different than a small pool, but buying and hauling bleach bottles got old for me really quickly.
that may be the long term answer
but will try the little tweaks over the next weeks
thanks again
Hi
Just bought some 12.5% liquid chlorine. Should reduce the # of empty bottles.
Nice store, no retail fancy stuff, just a pool service. And the man seemed quite knowledgeable. He also suggested SWG.
pH of the stuff is 11.2
this might explain my acid burden
he said several of his commercial pools with liquid feeders also have acid feeders
several tfp threads comment on this as well
so maybe I do not have two problems, just one; jugs and jugs of liquid chlorine
The pH from adding liquid chlorine ends up being almost neutral. The pH is shifted back as the chlorine is consumed.
Anything that aerates the water, including splashing, drives up pH and necessitates adding acid. Bubblers, waterfalls, negative edge pool, etc.
so I set out to work on the tweaks to see if can fix too many empty bleach bottles and too many additions of acid
started by tracking FC today, very sunny day
here it is
5:00 FC11
8:45 FC 8
12:00 FC 6
1:44 FC 4
3:45 FC 3.5
5:50 FC 2.5
I also had not tested CYA for a couple of weeks so did same and found that
little black spot shows even if comparator full so not much CYA
I don’t have liquid CYA out here so
at this point I turned on the Rainbow with 5 tabs and setting 3 since the tabs have CYA
then
8:44 FC 2.5 (of course sun is gone now)
will see what happens tomorrow
as per another thread, my funky too intense pH color discussed in Oct last has returned so pH as the FC declined was doubtful; but it did not change as FC declined, funky at the start, funky at the end
with 5 tabs in the Rainbow and setting 3
FC stayed between 2.5 and 4 all day, even with hot sun
NO EMPTY BLEACH BOTTLES! PRAISE THE LORD!
and CYA should have gone up a little (still < 30 however)
will leave the Rainbow run all weekend and get some liquid CYA tomorrow in Bellevue
also new bottle of R0004
pH test remained funky all day so not reporting, did not change as FC went down, have ordered TF-100, then can compare to K-2005
by the way, IMO the little blue spoon is poorly designed
if you lay it flat side down, it is hard to pick up
since the handle is flat, it is hard to rotate to dump
since all other stuff is so slick, seems tftestkits.net oughta get a new spoon
could be called the troublefreespoon
You can modify your scoop to make it easier to handle. Either wrap the end in electrical tape so it gives it a little bulk and lifts it off the flat surface, or use a lighter to soften the end of the handle for about a second and bend it slightly up. Hold it in the desired position and blow on it to cool the plastic. It will hold the new shape. Just did this to mine as an example.
Hi
about the chlorine acid sink
pool is doing fine with Rainbow on 3 with 5 tabs
this AM FC 3.5 and no empty bleach bottles
pH still funky but 7.8 with 3 drops
CYA still <30
will get new R0004 and liquid CYA today
as for the spoon
will try your bend it up fix
person at TFtestkits replied no one else has complained so spoon unlikely to be changed
but now there are 3 and 3≠ 0
Well, he doesn't make the spoons and if you do a google search you will see there is not a lot of diversity of design in the tiny scoop market. That leaves it up to the user to make the modifications they need to optimize function.
