Thread: Calcium Hardness Test
    klavant's Avatar
    Jun 2008
    West Grove, PA
    36
    I just took a CH reading and noticed something unusual. After adding and mixing the R11, the water sample turned clear/red but had red "particles" floating in it as well. i would have expected the solution to be relatively clear. After adding the R12, the water sample turned clear/blue as expected and the "particles" as well.
    Could something be wrong with my reagents or water? TFT-100 Kit was ordered in May. Water tests and looks fine.
    FC=2
    CC= >.5
    PH=7.5
    TA=110
    CH=240
    Kurt
    _______________________
    9,600 Gal. AG Vinyl
    Hayward C900 Cart filter
    2 speed pump (0.5/2.0 HP)
    Guest
    Re: Calcium Hardness Test
    No, that is normal with water that has either high magnesium or metals in it. This can be minimized or eliminated by swirling for 20-30 seconds after adding the first reagent and swirling 20-30 seconds between EACH drop of titrant. If you do this test properly it takes a while.
    klavant's Avatar
    Jun 2008
    West Grove, PA
    36
    Are either of those conditions something to worry about? And the test results are still reliable, correct?
    Kurt
    9,600 Gal. AG Vinyl
    Guest
    If you are getting a distinct endpoint it's nothing to worry about. It's actually somewhat normal if you are not using a magnetic stirrer for the test.
