2004 sundance optima breaker tripping
Ac88
Jul 4, 2014
1
Philadelphia pa
Hello, I have a 2004 Optima. The breaker keeps tripping. I removed the front panels, rest the breaker, turned pump 2 on and it works fine. Now I turn pump 1 on and it trips the breaker. When I turned pump 1 on I noticed smoke coming from the circulation pump as it tripped. I took the cover off the back of the pump and it looks and smells like it's the capacitor. I disconnected the circulation pump, rest the breaker, turned pump 1&2 on and it's working fine. Do you think it's the circulation pump or could the heater be causing the problem? I didn't disconnect the heater but it's not tripping the breaker either when the circulation pump is disconnected. Thanks for your help
Welcome to TFP Ac88!
Lets see if someone can help you trouble shoot this.
