Results 1 to 7 of 7
Thread: Atomic Buffalo Turds (ABT's)
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Atomic Buffalo Turds:
    20-30 Large Jalapeno peppers (this will make 40-60 turds)
    1 block cream cheese, room temperature
    1 package thick sliced bacon
    40-60 toothpicks
    Small package of Little Smokies
    (The amount of peppers determins the finished turds)
    Take the peppers, cut the off the stems and split them into halves. Now rinse out any remaining seeds from the inside of the pepper with cold water and place them on a paper towel to dry. Remeber, when coring the peppers - the amount of membrane you leave inside the pepper will determine how hot the turds are. The more membrane you leave, the hotter the turd will be. Use a small spoon or mellon baller to remove
    the membrane & seeds.
    Time for the cream cheese. If your cream cheese is not room temperature, it will need to be softened (15-20 seconds in the microwave) to make it a little easier to pipe. Spoon the cheese into the corner of a sandwich bag, cut a small hole in the corner to pipe in the pepper. Some people like to season the cream cheese with Mrs. Dash, liquid smoke or other spices/seasonings - just don't over do it. If you want to turn your buffalo turds into "atomic" buffalo turds just add some cayenne pepper in the mix.
    Place a little smokie or other choice of meat on top of the cream cheese mixture. Wrap the pepper with a piece of bacon and place a toothpick all the way through to hold it all together.
    Now your buffalo turds are ready for smoking. Some people place them in the cold smoke chamber on my smoker and keep them about 150-180 for an hour or so. You can place them into your main cooking chamber at around 225-250 let them cook an hour or so.
    Basicaly these things are "GOOD" so be sure too make plenty so the cook gets some to. If you remove all the membrane and seeds they are not any hotter than a pepperoni. USE CAUTION they are very addictive.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Atomic Buffalo Turds (ABT's)
    This is something I have to try. May also make some Habenaro ones and see how they are.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Round Rock, TX
    529
    Awesome, I was looking for this recipe!!
    thanks,
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Jun 2008
    Buffalo/Niagara Falls NY
    30
    What might you do if you don't have a smoker?
    sounds yummy!
    15x 30 inground oval vinyl lined. 15000gals. Jacuzzi 250lb sand filter. Laars lite natural gas heater. 6 foot slide, underwater light . 3.5 ft. shallow,to 7ft. deepend. TF 100 test kit
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    BBQ, low heat, in foil, with the top down...
    Quote Originally Posted by tvfoxy59
    sounds yummy!
    DrDave
    http://plansbyjorde.tripod.com
    Necessity is the Mother of Invention
    Jun 2008
    30
    That makes sense!
    Heading to the store for the ingredients.
    Thanks!
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    you can do it unfoiled in a gas grill, just don't use direct heat. Put the opposite burner(s) on.
