G
Guest
BTW, lowering your TA has NOTHIHG to do with BBB. No matter what method of pool care you use you would need to lower TA. The method we uise here works and is based on science, not myths that have been entrenched into the pool industry. acid-column-myth-t1089.html
BBB is just good pool maintenance that usually uses liquid chlorine and generic chemicals and the main thing it stresses is testing your water so you know what to add and how much to add. It's not a 'magic method' , just good pool care. It's was pool service professionals have been doing for yeears and charging a lot of money for! I take care of some commercial pools and it's exactly what we do there. (Oc course, we use peristaltic dosing pumps for the liquid chlorine and acid and automate a lot of stuff but the basic priciples are the same. We actually test the water every 2 hours while the pools and spas are open, and we use Taylor test kits!)
