Thread: Question about IntelliTouch i5 with SAM/SAL lights
    Hi,
    My first pool quote came in and I was just looking at the equipment he specified in the quote.
    He included two SAM likes and one SAL light for the spa along with the IntelliTouch i5 controller for automation.
    From the Pentair user manual, it states (under lighting features)
    "Color Swim - Allows a combination of up to six SAm, SAL, or FIBERworks lighting circuits to be preset to transition through colors in sequence. This gives the appearance of colors dancing through the water. You can adjust the delay of each light to make the colors move at different speeds. This feature is not available for i5 or i5S systems.
    Color Set - Allows a combination of up to 12 SAm, SAL, or FIBERworks lighting circuits to be preset to
    specific colors. This feature is not available for i5 or i5S systems. This feature requires a separate relay for
    each light to achieve different colored lights."
    So my question is this: If the color swim and color set features are not available from the IntelliTouch i5 panel, how would the SAM/SAL lights going to be controlled?
    Thanks
    UKMatt
    37x20, 23,500 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    Jun 2008
    Scottsdale, AZ
    37
    Re: Question about IntelliTouch i5 with SAM/SAL lights
    The same way as if you did not have a controller. Turn off and then back on the power to the lights. They should start spinning.
    Gary
    18 x 38 28800 gals gunite inground;Purex Triton High Rate Sand Filter;1 HP 2 Speed Hayward Tristar Pump; Raypak Heater
    Aquabot Bravo; Goldline Aqua Logic Controller/SWG
