Thread: Scale and staining treatment.
    Not sure if this is the right place to post this question or not.
    I'm having some problems with calcium scale and staining from the dirty calcium. Has anyone found a good solution to slowly reduce these scales short of an acid bath ?
    FC 5.0
    PH 7.5
    CYA 58
    TA 115
    CH 400
    Thanks for any help.
    Rabbit.
    ~25k G 20x40 Free form plaster
    Pentair FNS Plus 48 sq/ft DE
    Pentair Challenger 1 HP High Flow E.E.
    Zodiac G4
    8 gal Liquidator 3/8 line conversion
    Sundance Palermo Spa w/ozone and gazebo
    LQ 3/8 Line Conversion
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Re: Scale and staining treatment.
    From what I hear high calcium (your is not terribly high) and high pH can contribute to calcium deposits. I assume you are having this problem at the waterline?
    An acid solution can be used with a lot of scrubbing to reduce this.
    I talked with a guy that will bead-blast the tile for about $1 per foot of perimeter. No too terribly expensive if it has to be done every 5-7 years or so. Just do your reasearch on the hardness of the bead used and what damage it could do to your tile.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    I'm actually noticing some calcium buildup on the plaster as well, below the waterline. It was a process that started before we purchased the house. It's now become my problem.
    Zodiac G4
