Re: My Quest Begins - New Pool Owner
My skimmer isn't working. When the pump is on, no matter what I do on the pump side there is no activity (bubbles etc...) at the skimmer. When I run the water fall, spa, or suction at the main drain still no activity. I've tried snaking the line, compressed air, wet vac, and the Drain King and non of them fixed the issue. I did some research and came across a common Flex PVC issue. I have an Anthony Sylvan pool and I'm almost sure that the Flex PVC is the cause of my skimmer not working. I'll be digging any day now and will replace the PVC. I'll need to do more reading to find out why people are choosing Flex PVC and the other gray PVC (I forget the name). I'm not sure what I'll be replacing the flex pvc with but as long as I can get it working.
In my search I came across
this thread and for the record I have the two holes and have the small plastic disk that goes over both of the holes. I'm not sure if the second hole is capped, go to the waterfall, or the main drain.
Any constructive suggestions are more than welcome. I'm aware of placing a jack and block under the concrete when I dig for support.
Two questions:
1: If the skimmer repair is more than expected can the pool still be used?
2: The spa jets never have the force you would expect from a spa. Is this normal, pumps not strong enough, pressure leak or? (I have a pump that operates the spa and waterfall and one that operate the pool.)
Thanks in advance!
