Hello so I'm new to a pool this summer, with a 22ft intex 10,000 gallon above ground pool.
I have had a few problems but it all seems to keep coming back to the white build up on the intex salt system plates. They are getting Calcium Buildup/Scale/Whatever else, this is causing a low salt error, which is causing the chlorine to not be generated. I then Boost the system only to increase the buildup. See the problem.
It took a couple of weeks for me to get the water within range via pool store testing, but my struggles with the salt system have been my biggest headache, keeping chlorine in the pool.
I have attached a photo of the buildup. Last time checked at pool store, I had perfect amount of salt, My hardness level and been at 200ppm, TA was perfect, now high at 140, and CA was perfect, now low, PH has increased this week as well.
Any ideas what I can do to?
Thanks
Thanks
