AutoPilot error message
wbrady
May 15, 2007
22
Maryland
It said Purifier Off
Revisar OpEC (looks like revisar is spanish for "check")
We have had numerous power bumps (very short power outages) latley. We did have a outage yesterday moring and I noticed this when I returned from work.
None of the buttons would respond so I had to unplug the AutoPilot and plug it back in. Everything was in spanish. I figured out how to get it back to english and found that all the setting were incorrect. The cell type was wrong the cell power level was 1. I change it back to the correct cell and power level 2. I set the salt level and pool volume.
The temp display is reading 13 degrees lower than the acual temp. Tried to adjust but the adjustment is only for 6 degrees.
It appears to be working, but I'm thinking I need to call a tech. Anyone have any suggestions.
Thanks
