Results 1 to 9 of 9
Thread: Hard pipe ABG
    Mar 2007
    Texas
    443
    Hard pipe ABG
    Not sure if this is the right place for this, but I figure it is a repair so, I am going to hard pipe my ABG pool, What I need to know is, at the return and the skimmer, you have a slip fitting(where the flex hose slides over it and then you clamp it) What would you use on this fitting to connect hard pipe to it?
    27' Round AG, 17,200 gallons, sand filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Hard pipe ABG
    On our pool we have from the filter to the return eyelet from the pump a flex hose that slides over the hard PVC pipe and is clamped at both ends with an adjustable I guess you call it a ring clamp?
    From the skimmer we have it hard fitted to the filter.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Re: Hard pipe ABG
    I used a reducing rubber boot, 2 inch to 1.5 inch. My skimmer had a small crack where someone overtightened the hose barb so I used a rubber boot to go over the cracked area. It attaches with two clamps one on the skimmer, one on the pipe. You can pick them up at lowes / HD with the DWV (drain waste vent) boots.
    Patriot Arcadia 15' round 52". Pentair Clean and Clear 100 sqft Cartridge filter, 1HP Optiflow pump, Goldline Aquatrol SWG. 2 - 4'x20' solar panels roof mounted. All rigid PVC plumbing. Resin Solar reel with 8mil Thermo-tex solar cover. 14 x 12 deck.
    Ovation 15'x24'x52'' AG. Pentair System 3 150 SQ foot cartridge filter, 1 1/2 HP pump.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Hard pipe ABG
    We have one of these to connect our pool outlet(to filter) to the hard PVC piping.
    It can be found here: http://www.lowes.com/lowes/lkn?actio...X40&lpage=none
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    98xc600's Avatar
    Jul 2007
    Southern MN
    148
    Re: Hard pipe ABG
    Take a close look at it. I had the same thing but the slip fitting was threaded into the skimmer and return. I spun that out and a male adapter treaded right in for you to glue your pipe to!
    16' by 32' cornelius AG vinyl liner, 6' deep end, 14500 gal.
    Hayward 250 Lb sand filter
    Hayward 40 GPM pump
    2-2' by 20' sun grabber solar heater.
    4 gal Liquidator. BBB
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hard pipe ABG
    This has happened 2X in the past week --- I type a reply and it never shows up The 'Fernco's' pictured are ok, but tall you need to do is remove the slip fitting and replace it with a male adapter, so you can glue the hard pipe into it. If you need any help with PVC plumbing, just ask and I'll 'walk you through it'
    Luv& Luk
    -Ted
    Mar 2007
    Texas
    443
    Re: Hard pipe ABG
    Thanks to all for the replys, I could not find a rubber boot with the 2 sizes I needed and I did not want to drain the pool below the return to be able to remove the fitting at the return and skimmer, So I think I can take a male adapter and glue the slip part over the return pc (or skimmer) and use the threaded end to screw my shut off on to, Anyone see any problems with this? Ok I am off to go play plumber I have been told, All I have to do to be a plumber is to be sure my ummmm "rear" shows when I bend over Disclaimer: to any plumbers on this site , that is my attempt at humor
    Mar 2007
    4,160
    Re: Hard pipe ABG
    Um... it's customary to plug the return and skimmer when playing with the plumbing :P
    Luv& Luk
    -Ted
    Mar 2007
    Texas
    443
    Re: Hard pipe ABG
    ummmmm, I tried to but didnt work to good on the skimmer side, BUT I did do it that way and changed the fitting 8)
