Newbie-New (Green) Pool-Looking for Advice
Back for another update!
I bought myself a DE filter on sunday, and the last few days, i've seen dramatic improvements in the clarity + color of the pool.... maybe I had a bad / inneficcient sand filter?
CC is now fluctuating between 0 and a tiny bit over 0
I'm still SLAMing.. so I still try to keep my FC near 16ppm
Tried the OCLT last night.. and only lost 1.0ppm!
And the best news.. this morning I was able to see the bottom of my pool!
Here is my pool this morning:
Replies in red.
Did you try deep cleaning your filter?
It's not necessary to get 0CC but you can if you want.
Well done! I'd run it a second time for confirmation.
Well done! Based on what you're reporting it sounds like you've fulfilled all 3 criteria to end SLAM.
My CYA has been holding steady at 40 PPM.. I have been testing it almost daily.. but since I've gotten the DE filter, i've had to backwash/vacuum to waste less than with my old sand filter so it's holding a bit more steady.
I have to admit that i'm still not 100% confident in my ability to do CYA readings.
However, I did order the 50ppm standard solution from TFTestkits.com - Hopefully, I will receive that shortly and can use that as a guide to verify my readings.
FC Loss last night was 1.5PPM.. so looks like I can't end the SLAM just yet..
The pool was clearer this morning (I can see the bottom in greater detail), which helped me notice a few pockets of (probably) dead (white) algea at the bottom - vaccuumed them up best I can.
But I can finally say i'm close to the end!!
This forum has been instumental in me getting this far.. I still can't believe how clear the water (even though it is still a tad bit cloudy) is now compared to what I started with..
I couldn't have done it without you guys!
