Thread: Pool Skim
    billybrobob's Avatar
    Apr 2008
    NW Florida
    31
    Pool Skim
    I bought a Pool Skim two months ago. I like it!
    40,000 gal pool, Goldline SWG, 1.5 hp pump, sand filter, plaster w/epoxy paint.
    Re: Pool Skim
    Quote Originally Posted by billybrobob
    What features set it apart?
    Is there something special it does vs. the competition?
    Inground, 2 yrs old, all Jandy gear.
    http://www.laspeedgarage.com
    Apr 2008
    NW Florida
    31
    Re: Pool Skim
    It works as advertised. As a gadget guy, this is kinda rare. I leave it in all the time and it catches at least 90% of my debris. Easy to clean. Nothing to really break. one-half psi increase on my pressure gage. I have not tried other product (dirt devil line?) but there is discussion in archive.
    I use skimmer socks for a silt problem in my area. I clean socks when they are clogged with silt/pollen, not from leaves anymore.
    Re: Pool Skim
    I'm looking forward to a major leaf problem in the fall.
    Since I am my own "pool guy" this year this looks like it might help.
    It looks like someone will inevitably bump into it and break my 20 year old plastic outlet insert since they weren't designed to serve as an attachment point.
    Is that a threat?
    How secure is the attachment?
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
    Apr 2008
    NW Florida
    31
    Re: Pool Skim
    I also have a twenty year old inlet. 1-1/2" pvc pipe, no threads. Therefore, the pool skim insert is only a friction fit. I had to use pvc glue to build up the insert (will not be permanent if done underwater. don't use an epoxy). The kids' floats bump the skimmer and occasionally it will loosen and fall out. But I figure thats okay, it is a safe weakpoint. I have thought about tapping my inlet pipe, but this works well enough.
    The inserts that come with the pool skim facilitate an off-the-shelf fountain(s), which is good for raising your ph without affecting your alky. And they're a lot of fun.
