Just too easy! Thank you TFP!
Great Job! :goodjob:
Assuming that your pool is not a salt water pool, just keep an eye on the CYA level to make sure it does not get any higher. Also, I do not see a calcium (CH) test. At some point, I would test for that just to see where it stands. Since your water is perfectly clear along with the fact that your numbers look good, I do not see the need for any adjustments right now.
