Wall Thickness and concrete psi
I believe walls are typically 6 to 8 inches thick. How deep is you pool? Based on the gallons it appears to be a sport pool. The deeper it gets the more stress there is ont he concrete.
It is unlikely that you would ever get less than 4500 psi from either concrete or shotcrete -- especially with shotcrete as it goes on drier (the lower the water / cement ratio typically the stronger the concrete).
Steve
