Wrong test kit?
Jul 16, 2008
26
SW Michigan
I think I bought the wrong test kit... I bought a Taylor K-2005 at my local PS today since we are going to try and start BBB tonight. We have a new pool that we just filled. Is this test kit going to work? I knew I shoulda ordered the one reccomended here...
From what I've read that's a good test kit but you are limited by not being able to test for chlorine above 5ppm. You can probably make do with that one for the time being but I would plan on getting the TF100. In my opinion it is much better.
Most of the Taylor K-2005 is great, but it doesn't have a FAS-DPD chlorine test. You will want a FAS-DPD chlorine test eventually. The FAS-DPD chlorine test is available separately if you want to add it on.
