Thread: Leaky DE filter
    Leaky DE filter
    Although the pool is clear and pumping well; I noticed a continual dribble from the valve on top of the large DE filter. The pressure reads about 19 (start-up was 15) so I don't think I have a pressure problem (I hope). Am I missing something? Should I be concerned? Any thoughts?
    Cement pool 50,000 gals. nine foot deep at one end
    kidney shaped. Large DE filter and pump.
    Re: Leaky DE filter
    Quote Originally Posted by JFP
    On the top of the filter there should be a pressure gauge and air relief valve. If the dribble is coming from the air relief valve, try tightening the part that opens and closes it. If it is from a connection, you can redo them using teflon tape.
    When you shut the system off can you hear air being pulled in through the top of the filter?
