Thread: Main drain cover busted
    OK, somehow my 17 year old managed to bust the main drain cover in my pool..even though it was 8 1/2 feet down. I'm having a hard time trying to locate a replacement. It's got a big hole in it.
    The markings on it are Ccsi (Fancy C__) 4-1-10-20
    Any help at all would be appreciated.
    Rabbit.
    ~25k G 20x40 Free form plaster
    Pentair FNS Plus 48 sq/ft DE
    Pentair Challenger 1 HP High Flow E.E.
    Zodiac G4
    8 gal Liquidator 3/8 line conversion
    Sundance Palermo Spa w/ozone and gazebo
    LQ 3/8 Line Conversion
    Dec 2007
    Central New York
    504
    Re: Main drain cover busted
    I'll answer just to bump this thread up to the top.
    Only thing I can think of is to go back to the pool builder and ask.
    Any pieces get into the bottom drain plumbing?
    Sorry, I'm no help.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    It's actually a non functional drain. The pool use to have pop-ups at one time. The previous owner opted to cover those up when they had it re-plastered. It would appear they also did something to the plumbing for the main drain as well. The pipe is there, everything looks right but it has no suction and I can't find a pipe on the other end. So my replacement cover is just for cosmetics only. Kind of sad, but not much I can do about it without digging all over trying to find the other end of the pipe...if there is one.
    Zodiac G4
