Thread: Do I have a potential problem
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    When I put my numbers in the pool calculator:
    FC=3, pH=7.4, TA=70, CH=200, CYA=60, borates=50, salt=3100 and the temp is 85.
    I get a CSI= -0.64. Is this a problem or a potential problem?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Re: Do I have a potential problem
    No, no problem at all. You have a vinyl pool, so it is fine if the CSI is very low. You will only have a problem if the CSI is too high.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Well that's good news. I was/am still a bit nervious about my limestone coping and my CSI.
    I thought my numbers were pretty typical of a balanced pool. Which of them are out of whack if I had a gunite/plaster pool?
    As long as the limestone is above the water line there shouldn't be any issue because of CSI. There is a small risk to the limestone from the salt in the water. I would use sealer on the limestone if you haven't already. Rinsing it off with a garden hose once a week might also be a good idea.
    In a plaster pool I would raise CH to 250 or 300 and try to keep PH between 7.5 and 7.8. But with vinyl you should be fine.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Thanks, Jasonlion! I see that a small change in pH and CH make a big difference in the CSI.
