Woohoo! Congrats on sticking with it and testing your POP. Victory photos mandatory!
See here Posting Photos Tutorial
POP: Pool Owner Patience - usually hardest to maintain patience at the end of a SLAM, when pool looks great, CCs are low and OCLT is the last hurdle. Time and trust in what you're doing are sometimes the only cure.
Those look fine. TA might be creeping a tad low, but for now aeration will raise your pH over time so you look good. Don't worry about TA for a bit. Just keep your FC in line with your CYA for a while and get the feel for your clean pool (balancing-wise and jump in!)
Do the full battery of tests when you can and post the whole shebang.
Everything looks great! I wouldn't touch TA yet either. Recommended is 70-90+ but at this point I'd keep an eye on pH. Your pool might just like it at that TA and raising the TA might just make your pH rise more quickly. Normal aeration should raise your pH slowly over time.
Keep an eye on your FC daily usage once you start having to dose to keep it in the recommended range. If you're losing more than you'd like during the day to sun, you could look at bumping CYA to 40 to try to help that. Also depends on if you have any vacations or will be gone for several days and might want to leave some CYA room for puck usage.
