I have a 23000 gal saltwater pool with a Pentair IntelliTouch system. There are two Jandy 3 way valves with Compool CVA 24t actuators. One of the actuators does not move. I have toggled the rear switch and it does not work. I opened the Intellitouch box and switched the actuators connections and the same actuator failed. So I guess it needs to be replaced. Do I have to replace it with the same brand or could I use a Jandy or Intermatic or other??
I'd appreciate advice.
