Pool Chemistry Questions
Apr 23, 2014
17
Shreveport,La
Need help from you chemistry wizards!!!:D
I test at home with my Taylor k2006, and also verify if I get strange results with my LaMotte color meter. I am also required to bring occasional samples to my PB store for my plaster warranty. So I will post both my results & pool store for today.
Taylor K 2006.....................................Pool Builder/Store
FC 4.5......................................................FC 4.63
CC 0.......................................................TC 4.63
PH 7.5.....................................................PH 7.7
ALK 70 (25 ml Sample)...............................TA Input 81 (adjusted TA 60)
CH330.......................................................CH 175 (theirs is always lower than mine)
CYA 60....................................................... CYA 64
............................................................... Copper 0.1
....................................................................Iron
................................................................... Borates 0
I am going with my own PH. Did it 3 times.
1)I do not have borate test strips, stores here do not sell them, but tested for Borates at their store two weeks ago and Borates were 50. I didn't think Borates would just disappear unless we did a water change.??? I am suspect if their test is accurate. Guess I need to get strips online, any recommendations for brands?:confused:
2)Also. can anyone tell me the difference in adjusted TA? I thought that only applied if I had borates in the water?
3)Should I be concerned about that copper and iron? Thanks!!!
Trust your own results, and just ignore theirs.
1) Borates can't possibly go from 50 to 0 without a complete water replacement. Their test simply doesn't work.
2) Completely ignore adjusted TA, it is only used for one obscure calculation that no one ever does any more
3) Copper/iron below 0.3 can be ignored.
