Be aware that if the main drain is not separately plumbed, you'll only be able to drain down to the skimmer, and then it will start sucking air and loseprime.
If you have valves to shut off the skimmers and open the main drain, that's what you want to do. If you don't have a way to draw water only from the main drain, your best bet is to rent a submersible pump.
