75x9 Lap Pool Questions
toschirripa
10
melbourne beach
We are in the “just poured concrete“ phase on our 75’ x 9’ lap pool. we only got quoted 3 lights...should i be asking for more? also love to hear about for wave action reduction and a chill system. this is our pool...
i was told by PB that limestone and salt play well together. we are planing to put “Stone District” shell reef (limestone) as our deck. Our current hose has travertine but we went w limestone bc we heard it was “better” - were we fools? btw- i vote for straight edge if you have modern type house and bullnose if it’s a traditional house.
kimkats
44,867
Tallahassee, FL
I am very surprised to see a 3' depth in a "swim" pool. You will not be able to do a full crawl stroke with 3' depth without scraping your knuckles. Make sure it IS at least 3' WATER DEPTH then you can keep if a bit fuller than normal to help with it some.
As far as to how to stop the waves I really don't know how you could do so.
Kim:kim:
ajw22
16,299
Northern NJ
If I read the spec correctly your pool will be 21,600 gallons. You need a larger SWG then the 30K iChlor and a larger filter then the 200 C&C. I would suggest you get a VS pump.
We recommend your SWG be at least 2X your pool volume. Get the IntelliChlor IC40 or IC60.
Get the CCP420 or 580 filter.
toschirripa
10
melbourne beach
Kim:kim:
ack - pool is already poured so i can’t change the 3’ ... luckily i’m short -), but i will check w the PB if it’s 3’ water depth or 3’ pool depth... good point.
Reactions: kimkats
toschirripa
10
melbourne beach
i have attached pics before the pour and after. unfortunately, we didn’t know they were going to start... original date was summer!!! we found out when we went to check on the house build and saw the pool there! house in picture is the neighbors house - our house is under construction.
PoolGate
4,532
Damascus, MD
Wow beautiful! Can we swap houses for a couple weeks? You want to visit the Washington, DC area?
