Results 1 to 9 of 9
Thread: Pool light question....
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    I have a 500w niche lamp in the deep end of the pool. I replaced the lamp when I opened the pool this spring. I haven't had the light on very much until just recently as we are spending more time in the pool after dark. The light will stay lit for 30-40min, spontaneously turn off for 10 min or so and turn back on...and repeat that cycle. The GFI never trips. Any ideas?
    "Beer is proof God loves us and wants us to be happy." -B. Franklin
    In-ground, vinyl lined, 20'x40', 3-10' deep, solar heater, sand filter, 3/4hp pump, Dolphin Pro, Cover Star Auto Cover.
    A proud BBB convert.
    Ft Lauderdale, Florida
    1,455
    Re: Pool light question....
    The light fixture has an internal high temperature overload feature that will do as you're describing. There should be water flowing into the light niche housing and surrounds the light fixture to help keep it cool. If this is sealed off somehow, it's not allowing the water to get in there to cool it off.
    The light fixture itself (the physical component that the bulb is in) should be completely sealed off to water.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    Poolsean,
    There is plenty of water circulation in and out of the niche and the fixture is sealed and dry.
    1,455
    The only other component is the 12 V transformer...unless you have a much older pool and it's 120 volts.
    A 500 Watt system is not too common anymore.
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    There's no transformer...it's an older 120v system. The pool itself is 18 years old. The fixture is a Hayward.
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Are you sure that a 500 watt bulb is what it took? Mine took a 300W Halogen tube bulb, the kind like go in the 500 Watt Halogen work lights that Wally-world sells. Finding a 300 watt wasn't too hard, our local Rural King carries it.
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
    May 2008
    Fair Oaks Calif
    44
    My last pool has similar light problem. It was a 300 watt, 120 volt bayonet mount bulb. It would quit after 15-20 minutes and then start working about 5-10 minutes later.
    Problem turned out to be corrosion in the base. Contacts and spring were corroded. After cleanup it worked perfectly.
    Not sure if you have same problem, but it might be worth checking.
    17000 gal free form plaster pool with 900 gal spillover spa, shared 2 HP 2 speed pump, cartridge filter, Pentair IC40 SWG, solar and gas heater, 1 hp pump for water features, 1.5 hp pump for spa. Dolphin Diagnostics robotic cleaner.
    DLO's Avatar
    May 2008
    Sioux City, IA
    47
    New2Me, yeah the fixture is rated for a 500w lamp. I replaced the bulb this spring with the same bulb that was in it when we bought he place. The 500 seems like it would be a little overkill, but the pool is pretty large (see sig) and with only one light, the pool is non too bright using the 500w'r.
    patf11, I have to pull the fixture out of the niche today anyway. I'll check the contacts and spring. I called Hayward a few min ago and they said it sounds like that if a bulb replacement doesn't fix the problem, the themal cut-off switch in the fixture went bad and I'll need to replace it.
    Jul 2008
    Bellevue, Washington
    7
    New guy, first post. I recently replaced the quartz halogen bulb in my underwater pool light with a tungsten bulb. The light works but it looks like the fixture is full of water...is that possible? I'm not a big fan of electricity, thanks to a couple of close calls, and am of the opinion that it's akin to witchcraft. I'm going to take the fixture apart tomorrow and install a new gasket...but I'm curious. Zoltan
    22K, in-ground, plaster
    Pentair,TR100 Sand Filter
    Coates 45KW, 188 amp, 240 v heater
    Sta-rite 1.5 hp pump
    Pentair Model 300 chlorinator
